Troubleshooting
andrzej-skiba
Dynatrace Contributor
Summary
This troubleshooting guide will help you look up the SQL query that is running to pull data for a particular metric for a SQL extension.
Problem
When working with metric data generated by a SQL extension sometimes it's useful to know the SQL query that generated the metrics to understand that data batter.
Troubleshooting steps
  1. Go to HUB tile → Download (Release Notes / expand version → Download Version). Read file extension.zip/extension.yaml from the zip file.
  2. Find sql* section (sqlOracle, sqlPostgres etc)
  3. Look in the extension.yaml for a metric key. It will be besides a specific query. For example:
interval:
    minutes: var:query-interval
    query: >
      SELECT
            CONT.NAME,
            CAST(CONT.OPEN_TIME AS DATE) AS OPEN_TIME_CASTED,
            CONT.OPEN_MODE,
            CONT.RESTRICTED,
            INST.INSTANCE_NAME,
            CDB.CDB_NAME
        FROM
            GV$CONTAINERS CONT
            JOIN GV$INSTANCE INST ON INST.INST_ID = CONT.INST_ID
            CROSS JOIN (SELECT sys_context('USERENV', 'CDB_NAME') as CDB_NAME FROM DUAL) CDB
    metrics:
      - key: com.dynatrace.extension.sql-oracle.database_topology
        value: const:1
Version history
Last update:
‎16 Jul 2025 06:28 AM
Updated by:
Comments
AntonPineiro
Nice tip! :take_my_money:
