dominikus_randy
Dynatrace Enthusiast
Why Tomcat Appserver Dashboard is empty or why Tomcat JMX Metric is empty?
If I go to Tomcat process dashboard -> Appserver dashboard is empty
And all JMX metrics are empty
Root Cause:
This issue happened when Tomcat is loaded by the Spring Boot framework. By default, the Spring Boot framework disabled the JMX MBean.
Solution:
The JMX Mbean can be registered in Spring Boot by setting the below parameter to true:
 server.tomcat.mbeanregistry.enabled
Refer to https://github.com/spring-projects/spring-boot/wiki/Spring-Boot-2.2.0-M4-Release-Notes#tomcats-mbean... , quoted below:
Tomcat’s MBean Registry
Tomcat’s MBean Registry is now disabled by default, saving approximately 2MB of heap. If you want to use Tomcat’s MBeans, for example so that they can be used to expose metrics via Micrometer, set the server.tomcat.mbeanregistry.enabled to true.
Comments
ChadTurner
DynaMight Legend
DynaMight Legend
Thanks for sharing this easy fix @dominikus_randy
New Article
Version history
Last update:
‎02 Jan 2023 06:41 PM
Updated by:
Contributors
