 a_barbera
			a_barbera
			on
		17 Jan 2024
		12:23 PM
 - edited on
		17 Dec 2024
		06:38 AM
		 dawid_rampalski
			dawid_rampalski
⚠️ If you haven't created an alerting profile yet, please read the steps provided in the documentation. Link here.
In some situations, we expect an alerting profile to detect a problem, but it doesn't. In this troubleshooting post, we're going to review the top main causes.
If the Alerting profile was created or enabled when the problem was already open, you aren't going to see the desired Alerting profile on that problem.
We will have to consider two things:
3. Once we click, we can see Revision History. In there, we have an overview with different information regarding the changes that have been applied:
At the top left corner, the ID of the alerting profile is shown. Then, we will see a new row every time we make a modification regarding our profile. In each of the changes, we can see when it was made, what type of change it is, and what the original and new values of the recent changes were. If we switch to advanced mode, we can compare everything we had before with the new values in a detailed way.
Suppose we have an Entity "A" with management zone "X":
Sometimes, when a problem is created, the impacted entity doesn't have the X but we expect to see it on A.
Usually, we see that A doesn't have X due to a problem related to the management zone rule. We recommend checking the following in management zone settings:
That is why it is important to check step number two, as it is crucial to verify if the rule applies to any entity we have in our environment.
If you're using event filters, you need to verify how they are configured. Here you can see some typical problems we see with event filters:
2. For metric events, it would be necessary to use the custom filter. Below, you can see how it looks like the custom filter works. You can use, for example, a title filter, but there are other options like description or property filters.
Once you have checked all the steps that are shown in the article but the issue is still not solved, please proceed to open a support ticket with the following information:
Regarding "Custom filters don't match any predefined events.", something to note that's maybe not obvious to everyone (at least wasn't for me):
If you have a profile e.g. with "Error after x mins" and "Custom after x mins", and then you add a filter for "Custom: Title does not contain <stuff>", then it will work for your Error events and any Custom metric events which do not have <stuff> in the title.
However, if you define "Custom: Title contains <stuff>", you have just now filtered out all your predefined events from the alerting profile scope. Because none of the predefined events will have that custom title, of course.
This behavior is not really logical to me, because I'd expect the predefined filters to only apply to predefined, and the same for custom. But this means that if you have any "include" definitions for metric events, you need to create 2 separate alerting profiles: one for predefined, and one for custom.
Hey @kalle_lahtinen , thanks for your pointing this out.
We have reviewed your comment internally, and now it is possible to filter predefined events using custom filters. I have modified the article so is clear also for everyone. Appreciate your collaboration in this!
