02 Jul 2018 12:21 PM
Could you tell us whether it is needed to restart the target application when we will stop all of the monitoring that OneAgent does?
We guess it is needed because of ejecting the injected sensor from the application.
Best Regards,
Noah Kobayashi
02 Jul 2018 12:33 PM
Correct. You need to restart the process to get the injection removed.
02 Jul 2018 12:45 PM
Thank you for the quick response.
