11 Jan 2019
08:28 AM
28 Sep 2022
10:37 AM
Hi, in my architecture, i installed Glusterfs as sharing filesystem. I wanna try to monitor if some host will be go down. Is there something or way to monitor via process and via disks? I know that dynatrace permits to to monitor a single volume but i want to monitor a Gluster volume that it is composed by more than one disk on more host.
08 Jun 2020 02:12 PM
you can define custom processes and such from the settings within your tenant . Let me know if you need a hand setting this up.
