Alerting
Alerts of 401 when received when trying to send to ServiceNow
tim2
Observer
I have a graph set to detect 401 on a alert profile. I'm hoping to create a alert based off this? Any advice?
T
3 REPLIES 3
dannemca
You can dot it using Metric Events: https://www.dynatrace.com/support/help/how-to-use-dynatrace/problem-detection-and-analysis/problem-d...
Example:
Metric: dsfm:server.notifications.problem_notifications
You can filter by a specific alerting profile, integration type, etc or let it generic, with filter by RC only.
Try and let us know.
Thanks for the advice, did it in metric selector instead. Im trying to get it pick up on a alert profile so i can send to a slack channel, figuring out how to tag it.
dannemca
In Alerting profile Event filter, you can select the metric name (title) you just created.
