29 Sep 2021
09:26 AM
15 Nov 2021
02:20 PM
Hi guys,
Not sure sure if high or low number of percentage is effecting the sensitivity here:
i.e. if we want this anomaly detection rule to be less sensitivity should we put 1% or 99% - can any one helps with explanation?
Yos
30 Sep 2021 09:24 AM
Yos,
The lower the values the less chance you'll get alerted.
Gil.
28 Nov 2024 09:44 AM
Hello @gilgi
Need quick understanding on Load drop alerts.
If baseline or expected service load is 100/min and threshold for load drop margin is set to 15% of baseline, then alert will trigger if load is less than 85/min or 15/min?
Mohit
28 Nov 2024 12:24 PM
Less than 15.
Gil.
30 Sep 2021 09:55 AM
Don't know how this question found its way to NAM ![]()
@MaciejNeumann can you help an move it to Dynatrace Open Q&A please?
30 Sep 2021 10:24 AM
Done 🙂
