The message you are trying to access is permanently deleted.
16 May 2025
07:47 AM
16 May 2025
10:01 AM
Hi Team,
Is it possible to disable alerting for the Builtin metric of GC in Java, tech.jvm.memory.gc.suspensionTime?
If that is not possible, can we disable the metric itself, like not collect data for GC, only for Java processes?
Vishnu
16 May 2025 07:59 AM
You can disable or finetune the settings it in the anomaly detection settings. Either globally, on a host or for a host group. It's not a setting on the process/process group, but on the host.
16 May 2025 08:01 AM
Hi Vishnu,
You can disable the GC activity alerting from anomaly detection configurations in global settings or host setting, so you can do it globally or on specific host. Hope that helps.
Islam
16 May 2025 08:38 AM
@Islam_Zedan and @Julius_Loman , thanks for the replies.
I dont want to disable GC collection for all Technolgies, only want to do so for Java. I did refer to the high GC settings, but that wont work for my case.
