12 Jan 2025 04:13 PM
Hello, community!
Currently, monitoring system triggers alerts for NotFound type errors. This is causing unnecessary alert noise.
I need to temporarily turn off an alert receiving from Dynatrace
Can someone guide me on implementing this temporary exclusion in Dynatrace to exclude these specific alerts while retaining log visibility?
Thank you in advance
13 Jan 2025 07:48 AM
Can you show one Davis problem example?
Best regards
13 Jan 2025 12:38 PM
I'm not quite sure what you're asking about, but I found this:
Metric name: Failure rate (client side errors)
Service: Consumer
Description: The error rate increased to 38.15 %.
Service method has a failure rate increase.
13 Jan 2025 03:28 PM
It means, do you want your problem is not present in Dynatrace console? Or your problem is not matching some alerting profile?
Best regards
13 Jan 2025 05:10 PM - edited 13 Jan 2025 05:12 PM
thanks for your participation
need to stop receiving exception alerts (40x) in monitoring for a certain service in a alert profile
I'm trying to do this using the failure/anomaly detection setting, but I'm stuck in the rules
13 Jan 2025 06:18 PM
I think that config should work.
Best regards
23 May 2025 08:09 AM
Hi @Pashu-Pati! Did you manage to solve this one? 🙂
