Filter out problems from the problem page
Hey all,
We want to find a way to filter out specific problems from the problem page.
We don't want to see anymore low disk space problems because we created an automation. But we don't want to disable them, because disabling them probably means that the automation will not work.
Any suggestions/ideas?
Thank you.
dannemca
The Problem filter does not allow you to exclude. You could check for this idea (https://community.dynatrace.com/t5/Product-ideas/Exclude-filters-from-the-problem-analysis-view/idi-...) which claims exactly what you need. Seems that you are able to do it using DQL.
dannemca
Or, you can create an Alerting profile, that captures all your problems, but the low disk space, then use this as problem filter.
Alerting profile:
as problem filter
