21 Mar 2024
09:30 AM
21 Mar 2024
10:51 AM
we have Oneagent monitoring on my servers in Full stack mode. recently we have been observing Host or monitoring unavailable alerts though i can see my host is available and running. i went through the docs where i found the alerts can occur if there is Network connection loss.
If there is Network connection loss to the monitored host , how can we identify this, and what fix/solution can be applied to avoid the Network connection loss
21 Mar 2024 10:11 AM - edited 21 Mar 2024 10:19 AM
Hello Athira,
which operating system and version of the OneAgent are you using here?
Have you tried a deinstallation and installation of the OneAgent already?
Christian
PS: I cannot open your link.
21 Mar 2024 04:52 PM
Hi @Athira,
You should see some gaps on any collected metrics at the affected host. In case of high CPU consumption / CPU saturation maybe OA did not have any CPU time and could not collect and transfer the monitoring data...
I hope it helps.
Best regards,
Mizső
