Alerting
WebHook custom integration issue
roberto_ravo
Guide
Hi all,
we are using the webhook downloaded from (https://github.com/Dynatrace/Custom-Webhook-Python) and periodically we encounter a problem that actually blocks the correct functioning of the webhook: after a while that the webhook is active it stops managing the problems correctly and returns this error:
Have any of you ever encountered a similar error using this webhook?
We can't understand how the number of open files runs out.
Regards
Roberto
Certified Dynatrace Professional
Miguel_RinconG
Dynatrace Advisor
Dynatrace Advisor
Hi @roberto_ravo,
Recommend use workflow .
