How to map problem severity to Opsgenie Alert priority field
serge
Newcomer
Dear all,
we are testing for a customer the integration of dynatrace with OPSGENIE.
We are using for that Opsgenie Dynatrace integration webhook v2.
In the payload we receive from dynatrace, we have a field name Problem Severity which we would like to map to opsgenie alert priority field.
But is seems we cannot do that from the integration as seen below
Does anyone have worked with such integration and mapping those field ?
Thanks for help
regards
3 REPLIES 3
ChadTurner
DynaMight Legend
DynaMight Legend
@serge were you able to get this to work out?
-Chad
Yes we manage to find a solution
hi @ChadTurner ,
Do you have the steps to this solution?
