23 Apr 2020
11:46 PM
17 May 2021
01:29 AM
Hi Team,
One of my clients wants to monitor the Talend jobs
They currently monitor all the jobs manually and check if it has been passed/failed and above all, they said it could be great if they can have an alert on failure
I know Dynatrace is capable of full-stack monitoring
But I need to know if we can monitor the jobs running in Talend and provide an alert on failure
If the Talend technology falls in the supported technologies then yes, If it doesn't you can always look at setting up agentless monitoring. But more then likely with Full Stack, Dynatrace will detect the process and alert on any issues.
https://www.dynatrace.com/support/help/technology-support/supported-technologies-and-versions/
