Alerting
Is there anyway the Auto-Alert-By-A.I and Manual-Threshold-Alert able to work concurrently?
Customer is asking about this. Any idea?
Any comment or insight is welcome.
One of the example, if a service or application (or if a key request or key user-action) has its anomaly setting override to be manual-threshold-alert instead AI-Auto-Alert, which one of the following does it means?
- Baseline is still generated by A.I for this application/service (or key req/key UA) but not used in alerting
- Baseline is not being generated by A.I anymore, specifically for this application/service (or key req/key UA)
Best Regards,
Wai Keat
skrystosik
You can create static thresholds for custom alert and keep using AI as well
Regards, Sebastian
