07 Feb 2024
03:54 PM
08 Feb 2024
07:50 AM
I have created custom log metric event which filter out failed cronjob and set this custom metric in anomalies detection metric event to monitor failed cronjobs . While setting an alert I have notice that dynatrace is triggering the alert when any job got failed and immediately triggers resolved alert for the same failed jobs . Ideally Cronjob that got failed is already failed and there is no point for dynatrace to trigger resolved status . As since Dynatrace does not offer any default cronjob metric event but still they can add filter in metric event which restrict dynatrace to send resolved trigger for failed cronjob
09 Feb 2024 02:20 PM
I saw you have edited the content , did someone acknowledge it @MaciejNeumann ?
27 Jun 2024 07:31 PM
@wolfgang_beer Is this something you can advise on?
28 Jun 2024 06:47 AM
Dear @akashkatoch ,
With log events you can trigger a problem that is kept open for a default period of 15min. In case the same log event appears again in this period of time, the problem is automatically refreshed and kept in active state.
You can add a custom event property with the value 'dt.event.timeout' = 60 to set the keepalive to 60 minutes to keep it active and open for a longer period of time.
In case you want the same problem to be open for days or weeks, there is no built-in mechanism in Dynatrace. This needs to be handled in an external ticketing system instead.
Best greetings,
Wolfgang
13 Aug 2024 12:36 PM
I think this is an alternative solution to cronjob to keep the alert alive for defined period of time . I need sort of notification based offering , because seems like metric event doesn't suits well with cronjob alerting.
