21 Dec 2021 01:09 PM
Hi Team,
Is it possible to monitor AIX errpt using DT oneagent?
Thanks in advance
23 Dec 2021 08:23 AM
If errpt is a process or invokes a process, you should be able to but if it is just an AIX command that produces a report from error logs, without invoking any form of process which the OneAgent can monitor, then I don't think you'll be able to.
What would you want to monitor here, exactly? Whether the errpt command runs successfully, or something else perhaps?
23 Dec 2021 11:51 AM
Thanks @andre_vdveen . errpt is a AIX command that pulls error logs without invoking any form of process.
In current setup through IBM Tivoli Monitor, we use a script that triggers "errpt -a" at regular intervals and results from it are string matched which is stored in a parameter file and if there's a match an alert is raised.
23 Dec 2021 02:22 PM
In the future, that might be possible through the use of custom metric ingestion.
https://www.dynatrace.com/support/help/shortlink/metric-ingestion
Unfortunately, at this stage, it is only available for Windows x64 and Linux x64, as per the prerequisites. AIX on PPC is potentially planned for future release https://www.dynatrace.com/support/help/shortlink/oneagent-support-matrix#other-modules (see module Extension Execution Controller)
27 Dec 2021 05:41 PM
@ssamraj you can use the same approach and push Events into Dynatrace to the corresponding host entity using Events v1 or v2 API.
For determining the correct HOST entity ID you can use the oneagent file open interface . Then you can easily push problem opening events to Dynatrace for such hosts.
29 Mar 2025 08:49 PM - edited 29 Mar 2025 08:51 PM
/etc/objrepos/SWservAt/*.log
/var/adm/ras/errlog/*.log
/var/adm/ras/errpt/*.log
/var/adm/ras/errtmplt/*.log
/var/log/errpt/*.log
If anyone has already configured this, please let me know.
