16 Mar 2022
11:25 AM
17 Mar 2022
09:54 AM
Hi Community,
I have a Kubernetes cluster being monitored using Dynatrace. On that, I need to enable notification alerting when a Pod or Node auto scales. Can It be done through any custom events for alerting?
As I checked on the below link for built-in metrics. I couldn't find a metric to achieve the requirement to monitor event for Pod or Node autoscaling.
Appreciate it if you guys can shed some light on how I can achieve this.
Thanks in Advance
Ref:
https://www.dynatrace.com/support/help/how-to-use-dynatrace/metrics/built-in-metrics
22 Mar 2022 11:11 PM
Hi LNarayanan,
You should be able to utilize the Kubernetes events and Dynatrace Log Analytics to create custom metrics for alerting. Here is the documentation on how to get started https://www.dynatrace.com/support/help/shortlink/monitor-events-kubernetes and setup custom events for alerting based on the metrics you created in the previous step. https://www.dynatrace.com/support/help/shortlink/metric-events-for-alerting.
Moe
