22 Feb 2024
07:33 AM
27 Feb 2024
08:44 AM
Hello DT Team,
Our JVM is frequently crashing and above problem message was added Dynatrace dash board. Please advise us on this.
24 Feb 2024 06:27 AM
Hello Paco,
Thanks for your prompt response. JVM is getting crashed frequently and I am getting " TCP connectivity rate for process websphere as xxxx on host xxxx has decreased to 0%:". Find attached screenshot from DT.
26 Feb 2024 08:01 AM
Try using Connectivity alerts
07 Mar 2024 12:02 PM
To enable this do I need to have admin access in Dynatrace ? As I am unable to find such option here. Please find the attached screenshot.
24 Feb 2024 12:31 PM
The connectivity problem seems to start before process is restarted. And after it is restarted, it doesn't turn back on, probably because your application is still starting. Connectivity issues can have many causes, but documentation,
https://docs.dynatrace.com/docs/platform-modules/infrastructure-monitoring/networks/how-to-monitor-n...
references some that are the more usual:
