Alerting
Monitor releases with Dynatrace
Hey,
We want to be able to see the status or events we had on each deployment, I know that Dynatrace can provide this service like in the link below:
https://www.dynatrace.com/support/help/how-to-use-dynatrace/release-monitoring/monitor-releases-with...
Can someone here advise how can we get this feature?
Also, if there is a better way to receive what we are looking for, I would be happy to hear.
Thanks!
3 REPLIES 3
r_weber
DynaMight Leader
DynaMight Leader
Hi @YuvalKonstanti
you basically have a few options to leverage the releases feature:
  • envionrment variables that you can provide to your processes/application code
  • custom deployment events that you push to your environment (e.g. through your CI/CD pipeline)
Both variants are described here:
https://www.dynatrace.com/support/help/how-to-use-dynatrace/release-monitoring/version-detection-str...
kr,
Reinhard
MarwanC
Advisor
I have implemented this feature nicely in our environment and all API worked perfect to push the right version on each process deployed. I am currently integrating it with our deployment pipelines.
I share this API call to help you, you need to create an ingest token and a tag to precise your process groups
              The JSON that I used  in this example:
  "eventType": "CUSTOM_DEPLOYMENT",
  "title": "PerfServlet Release",
  "entitySelector": "type(PROCESS_GROUP_INSTANCE),tag(Application-Functionality:PerfServlet)",
  "properties": {
    "dt.event.deployment.name":"PerfServlet",
    "dt.event.deployment.version": "8.5",
    "dt.event.deployment.release_stage": "PROD" ,
    "dt.event.deployment.release_product": "perfServlet",
    "dt.event.deployment.release_build_version": "5",
    " dt.event.deployment.project": "IBM"
EPL
Visitor
Thank you Marwan it was very useful.
