The new problem page needs to detail a bit more info about the current problems. In order to determine if a problem is an initial warning for response, or an all nodes failing 'bad' for transaction, you have to click in to the tile. A one line message would be incredibly helpful
Do you mean in the problem feed (list) or in the problem details screen? What kind of information would you expect for a larger problem?
Here is what I'd like to see happen. If we could provide a list version (like the old portal), that would be helpful to some groups (NOC).
Severity level filter does that sort of classification already, select 'Slowdown' Severity which would map to your warning Response time class and Severity Error does filter all error related problems. The problem icons also show that type of severity indicator.
Wolfgang, I am not sure we're on the same page. I don't want to filter. I want to see *all* problems, and be able to see what kind of problems are being raised. This may change as we migrate to being fully on the dashboard, but at present, all I see is the plug&socket icon. No turtles or whatever to indicate slowdown.
Yes I understand. Slowdowns do have the turtle icon. Availability problems have the plug&socket icon. Maybe your environment does not show any slowdown events at this time. Problems also automatically raise the severity if an error is correlated into the problem, so a slowdown can uplevel to an error or availability problem automatically.
