Alerting
Silence alerts within a certain period
HelderCosta
Frequent Guest
Hello everyone
I created a custom metric event that takes the number of invocations of a lambda function
Over a certain period, the number of invocations decreases and is normal behavior.
However, in this period of low access I receive alerts. I'm not comparing the solutions but in Grafana for example I can create a policy to silence the alert for a certain period, is it possible to do this in Dynatrace?
Hi!
Yes, you can set sliding windows.
https://docs.dynatrace.com/docs/shortlink/metric-events#sliding-window
Best regards
"The lions does not ally with the coyotes"
