Alerting
VMware virtual machines agentless monitoring
a_chiaravalle
Contributor
Hi team
We are monitoring vsphere configuring Dynatrace to connect to Vcenters and collect data about ESXi hosts and VMs.
My question is about the Virtual Machine monitoring, I would know if without oneagent on the VM and just using the agentless monitoring,  is it possible to have an alert when the CPU usage of the VM exceed a  threshold.
Kind regards
Antonello
3 REPLIES 3
Kor01
Helper
Yes, you can get some CPU, memory, storage, and network alerting just from the VMWare extension. This is configurable in Settings > Anomaly detection > VMWare.
extending Kor01's reply which applies globally to all VMs, you can create metric anomaly detection rules and be more descriptive over which VM's the rules can apply to, taking into account other properties of the VMs (tags, names, etc.)
a_chiaravalle
Contributor
Thanks for your reply.
Antonello
