Alerting
email notification on Synthetic HTTP Monitor failure with 5xx response status code only
DynaQ
Contributor
Is there a way to configure Dynatrace to only send an email notification when Synthetic HTTP Monitor fails with 5xx status code? I don't want to change the "Fail if status code is >=400" settings but want the emails to be sent for only the 5xx failures.
I tried to use the Custom event filter and define the description to contain 5xx, but that didn't work. Not sure which part of the problem is considered the problem description?
HannahM
Dynatrace Guru
Dynatrace Guru
Which metric did you use? Possibly this is better looked at on chat, so we can see the settings used
AgataWlodarczyk
Community Team
Community Team
@DynaQ do you still need help with your case?
Or have you already found a solution? If yes, feel free to share. Other Community members would be happy to know the answer.
When passion meets people magic and innovation happen.
