21 Jul 2022
07:00 AM
22 Jul 2022
12:37 AM
I got 2 alerts for the same issue referencing the same custom alert
P-22074136: Custom
P-22074137: Custom
Raise an alert if the metric is above the threshold for 3 one minute slots during any 5 minute period.
the event lasted 3 minutes
is it normal to get 2 alerts?
When does the sliding 5-minute period start?
Hi @billAtYale ,
What metric are you using, and are you splitting by any dimensions? Behavior should be, based on the info you provided, that a problem will be opened if the threshold is crossed for 3 consecutive minutes, and the problem will close if it is below the threshold for 5 consecutive minutes.
Were these two problems open at the same time?
Paul
