10 Jan 2019 11:06 AM
Hi
Could you please guide us on the below requirement?
We have got a new requirement to integrate MoogSoft and ServiceNow tools with Dynatrace.
Could you please provide us steps or any documentation?
Thanks&Regards
Siva
10 Jan 2019 11:20 AM
Here is doc for ServiceNow 🙂
https://www.dynatrace.com/support/help/integration...
10 Jan 2019 11:54 AM
For Moogsoft you would most likely want to push problems from Dynatrace to Moogsoft, which should be possible via a custom webhook. You should check the Moogsoft documentation for that.
10 Jan 2019 12:13 PM
Agreed. Pushing from Dynatrace to MoogSoft is the way to go. MoogSoft does have an out of the box integration on their side for Dynatrace, but all it's doing is a query and you have to provide credentials. I am currently kicking the tires on MoogSoft and found that going from Dynatrace to MoogSoft is the best method. Hope that helps.
10 May 2019
12:17 AM
16 Oct 2023
03:44 PM
random_user
Hi - when using the webook from Dynatrace, it is not possible to send the raw events... only a summary of the problem and the impacted entities that were there when the problem was first opened.
We have requested the RFE below for pushing events to any event management tooling - rather than being restricted to Service-Now ITOM module.
