Automations
Is it possible to keep track of libraries used in your application monitored by Dynatrace
Cbeecher
Participant
Hi is it possible to track changes to libraries used in an application monitored by Dynatrace, so you could see the dates / versions of when they were released / changed and use the information as an audit trail to check against what was approved and when?
I believe you can add version information to processes, is it possible to add versions / dates that can be seen historically to libraries?
bsnurka
Dynatrace Advisor
Dynatrace Advisor
Hey  @Cbeecher do you think it might be possible to add in ENV Vars to  your deployments tracking the embedded library versions? Via the Dynatrace Release Monitoring, there are two detection strategies you could implement. While not specifically designed to track embedded library versioning, you may be able to put together a solution that would work!
