Automations
Zabbix or alternatives for auto-healing
JB
Helper
I want to know if it is possible to invoke a script that is created in Zabbix, to restart for example some service if there is an increase in some rate.
In Zabbix we can configure the scripts to trigger an autoremediation. Maybe is something similar to keptn and Ansible?
Can you please suggest if this is possible? And how?
dannemca
Did you check if the Custom Webhook integration fit your needs? https://www.dynatrace.com/support/help/how-to-use-dynatrace/problem-detection-and-analysis/notificat...
Thanks I was checking this option.
