25 Nov 2024
05:49 AM
25 Nov 2024
10:06 AM
Hi , I am trying to create a workflow in my Saas tenant but getting this error "Uncaught (in promise) 400: TOO_FEW_PARAMETERS_FOR_FUNCTION. exceptionType: "DQL-SYNTAX-ERROR". syntaxErrorPosition: {"start":{"column":82,"index":81,"line":1},"end":{"column":93,"index":92,"line":1}}. errorType: "TOO_FEW_PARAMETERS_FOR_FUNCTION". errorMessage: "There aren't enough parameters for function in(). 1 mandatory parameter is missing: haystack. haystack: The elements where to search for the needle element (t"
I thought may be dynatrace-sdk/automation-utils needs to be installed first , but npm install @dynatrace-sdk/automation-utils is also failing. Does anyone know how to solve this issue?
Thanks!
27 Nov 2024 09:16 AM
Hello @Swabh
PFA Dynatrace resource for ease of troubleshooting:
hoping it helps.
KR,
Peter
