27 Sep 2023
12:54 PM
28 Sep 2023
07:58 AM
Hi Folks,
I have found a Go application in OpenShift (redhat costmanagement-metrics-operator) with inactive deep monitoring because of rule 47.
Is there any connection between rule 47 and Go monitoring settings second item?
Does rule 47 override the Go monitoring settings second item? Or there is not connection between them?
Does anyone have experience about this topic?
Thanks in advance.
Best regards,
Mizső
28 Sep 2023 09:40 AM
Hi. Both settings are connected. In order to monitor Go statis processes:
Also there is in Host settings a Go section where you can enable Go statisc monitoring only on individual hosts. Also in this case is needed to disable Rule #47.
28 Sep 2023 09:46 AM
Hi @joseandrescalvo,
Thanks very much for your explanation and help.
Best regards,
Mizső
