Container platforms
Does Dynatrace monitors Curl/Shell/echo script as processes via shell or process??
Sujit
Advisor
Does Dynatrace monitors Curl/Shell/echo script as processes via shell or process. If yes how can I exclude from monitoring them.
Tijust
4 REPLIES 4
ChadTurner
DynaMight Legend
DynaMight Legend
@Sujit were you able to get any information on this?
-Chad
@ChadTurner i know its late but still i haven't got it yet.
@Sujit,
You should take a look at https://www.dynatrace.com/support/help/how-to-use-dynatrace/process-groups/configuration/set-up-proc...
You can explicit define rules to not monitor them, but almost all shell scripts don't run long enough to meet criteria for Dynatrace to consider them.
Antonio Sousa
@AntonioSousa thanks for your reply, I will setup rules accordingly. I hope this should work.
Sujit
