25 Aug 2023
04:03 PM
18 Dec 2023
10:26 AM
IzabelaRokita
I'm trying to install dynatrace operator in openshift 4 using gitops as we manage all the configuration of the cluster and all the operators configurations there. We use a internal mirror for the redhat openshift/operators
For the subscription i use:
apiVersion: operators.coreos.com/v1alpha1 kind: Subscription metadata: name: dynatrace namespace: dynatrace spec: channel: alpha installPlanApproval: Manual name: dynatrace-operator source: redhat-certified-operator-index sourceNamespace: openshift-marketplace startingCSV: dynatrace-operator.v0.13.0
But i not find the proper OperatorGroup definition. I have try different options that do not work.
apiVersion: operators.coreos.com/v1 kind: OperatorGroup metadata: namespace: dynatrace spec: targetNamespaces: - AllNamespaces
18 Dec 2023 10:27 AM
Hey @jsolerso1 ,
do you still face some challenges regarding your installation or have you already found the solution? Let me know!
15 Jan 2024 02:36 PM
I still one open issue regarding the proxy and some nodes not connecting to the internal GW. I have to test last version 0.15 to see if this have been fixed if not i will open a dynatrace case. We need to fix this to allow install this in production systems
15 Jan 2024 02:33 PM
Yes i found the proper operator group and this is working fine
