03 Aug 2025
09:32 AM
17 Dec 2025
11:37 AM
Michal_Gebacki
Hi, not sure where I can raise this outside of the Q&A sessions for partners...so I'm raising the question here for debate.
There's a question that is in the Dynatrace Platform Architecture and New Apps Quiz.
Q: Deploying a Dynatrace Operator on a Kubernetes cluster will... (Select all that apply)
However according to the Dynatrace documentation, the Operator doesn't do any of these. 1/ K8s observability is provided by code module injection. 2/ Anomaly detection is done via Davis AI or in the Dynatrace Platform itself. 3/ ActiveGate deployment is done via a separate DynaKube deployment. 4/ EasyTravel is just a demo app done in a separate deployment. 5/ The Operator doesn't restart regular k8s applications pods.
In every instance of the documentation, the Dynatrace Operator "manages the automated rollout, configuration, and lifecycle of Dynatrace components in your Kubernetes environment":
I'm at a bit of a loss as to what's the expected answer here.
03 Aug 2025 09:39 AM - edited 03 Aug 2025 12:05 PM
Correct are the first three, although it of course depends on the broader context, which is missing the question. This is generally an issue with the exam questions.
for 4/5 you have correct reasoning - they are not correct.
03 Aug 2025 10:13 AM
Ok, thanks for the explanation. I think I see now that a DynaKube deployment is a part of the Dynatrace Operator, and ActiveGate is part of DynaKube. It's just not clear from Dynatrace Operator — Dynatrace Docs that DynaKube is part of the Operator deployment. I had to go into the GitHub repo to find that DynaKube is part of the k8s manifests.
I'm now worried about my prep for the Associate Exam and whether I've interpreted the documentation correctly!
