Kubernate Monitoring
SachinJindal
Helper
Does the Kubernate Monitoring License would cover Full Stack Monitoring of Apps which are running in Container Environment or this will only cover infra part ??
islam_zidan
Champion
You can choose from different deployment options, the recommended is the classic fullstack mode, in addition to API integration with the cluster, please check the below document for further details.
https://docs.dynatrace.com/docs/shortlink/installation-k8s#observability-options-for-kubernetes
Islam
Dynatrace Certified Professional - Dynatrace Partner - Yourcompass.ca
