18 Dec 2022
11:09 AM
19 Dec 2022
08:28 AM
Ana_Kuzmenchuk
Is there is minimum hardware specification recommendation for OpenShift cloud with SaaS setup?
as I am facing High CPU and ram requests.
I dont recall seeing a minimum requirement. Are you using the containerized AG or an external AG - Support Doc: https://www.dynatrace.com/support/help/setup-and-configuration/setup-on-container-platforms/kubernet...
