05 Oct 2022
07:37 AM
06 Oct 2022
08:39 AM
Hello.
How do I create a networkzone with the ActiveGate that was created in K8 (Openshift). I want all pods to use this AG?
I currently see pod connections to the AG in Openshift and to other Ags
Br
Jar
05 Oct 2022 08:23 AM
Hi @JAR
You can create a networkzone in the dynakube custom resource yaml. Uncommnet networkZone line and give a name to your networkzone.
05 Oct 2022 08:41 AM
Thank @Mizső s .
So.. if I use a new NZ name , it will be unique for the AG containerized and pods.
Correct?
Br, Jose
05 Oct 2022 11:49 AM
Hi @JAR,
It is correct in my opinion. I created netwok zones by openshift clusters level. Every single openshift (kubernetes) cluster has a network zone in my managed setup. Within a cluster pods communicate only the containerized pod (or pods - you can scale up the number og ag pods in the dynakube custom resource yaml.
Network zones | Dynatrace Docs
Br, Mizső
