14 Jul 2023 04:26 PM
I have the following query on a dashboard:
timeseries cpu=avg(dt.host.cpu.usage), filter:in(dt.entity.host,entitySelector("type(host),tag(Environment:DEV)")),by:dt.entity.host
| sort arrayAvg(cpu), direction:"descending"
| limit 20
And I have a variable called Environment with the values DEV, SANDBOX and PROD. I wold like to filter the tile based on the variable but substituting DEV by $Environment doesn't work.
Any idea on how could I create the query?
17 Jul 2023 08:39 AM
Hi @elenaperez
As you might have noticed from the info message in your environment, the entitySelector will be soon depreciated for usage in DQL. Instead you can use just plain DQL. I guess this example should work for you
timeseries cpu=avg(dt.host.cpu.usage), by:{dt.entity.host}
| lookup [fetch dt.entity.host], sourceField:dt.entity.host, lookupField:id, fields:{tags}
| expand tags
| parse tags, """((LD:tag (!<<'\\' ':') LD:value)|LD:tag)"""
| fieldsAdd tag = replaceString(tag,"""\:""", ":"), value = replaceString(value, """\:""", ":")
| filter toString(tag) == "Environment" and toString(value) == $environment
| limit 20
Best,
Sini
19 Jul 2023 11:36 AM
What if I also have another tag called Business_Application that works the same way as Environment and I want to filter on the 2 values? I tried this but it doesn't work (doesn't show any data but it should)
| filter (toString(tag) == "Business Application" and in(toString(value), array($Business_Application))) and (toString(tag) == "Environment" and in(toString(value), array($Environment)))
19 Jul 2023 12:12 PM
because for every tag you have now one record. This is caused by the expand command.
So you need to summarize again the data end extract the tags on which you want to filter. Something like this
| filter isNotNull(tags)
| expand tags
| fieldsAdd businessApp = if(tag == "Business Application", value)
| fieldsAdd environment = if(tag == "Environment", value)
| summarize {cpu = takeAny(cpu),
  businessApp=arrayMin(collectArray(businessApp)),
  environment = arrayMin(collectArray(environment))}
| filter in(businessApp, array($Business_Application)) and
  in(environment, arary($Environment))
Best,
Sini
12 Mar 2025 03:21 PM
I'm doing this same thing and am having issues with displaying as a time series on a dashboard.
| expand tags
| fieldsAdd client = if(tag == "client", value)
| fieldsAdd environment_type = if(tag == "environment_type", value)
| fieldsAdd function = if(tag == "function", value)
  client=arrayMin(collectArray(client)),
  environment_type = arrayMin(collectArray(environment_type)),
  function = arrayMin(collectArray(function))}
| filter in(client, array($Client)) and
  in(environment_type, array($Environment))
The data set comes out like this (with the tag values not shown):
The dashboard is telling my the data is not suitable for a graph:
Any help would be appreciated.
12 Mar 2025 03:51 PM
Try adding timeframe and interval in the by. You are missing that information when you do the summarize:
| expand tags
  , by:{dt.entity.host, timeframe, interval}
  in(environment_type, array($Environment))12 Mar 2025 08:09 PM
Thank you very much!!!! I am just getting into gen3 and DQL. Do you know what modification would be needed to report by entity name instead of the id?
12 Mar 2025 08:28 PM
Got it.
| lookup [fetch dt.entity.host], sourceField:dt.entity.host, lookupField:id, fields:{tags, entity.name}
| filter isNotNull(tags)| expand tags
| fieldsAdd function = if(tag == "server_function", value)
  , by:{entity.name, timeframe, interval}
| fieldsRemove client
|fieldsREmove environment_type
|fieldsRemove function27 Mar 2025 06:37 PM - edited 27 Mar 2025 06:40 PM
I want to revisit the original question because filtering in the timeseries query is faster than filtering after the query. In order to use a variable as part of an entity selector filter in a timeseries query, you need to use classicEntitySelector, concat and toString.
            classicEntitySelector(concat("type(host),tag(Environment:",
                                          toString($Environment),
  by:{dt.entity.host}
| sort arrayAvg(cpu) desc
| limit 20
Breaking down the filter, there's an embedded concat in the classicEntitySelector call with three arguments.  The first argument is the beginning of the entity selector in quotes.  The second argument is the variable converted to a string.  The last argument is a quoted close parentheses to end the entity selector.
Anything you can to do reduce the amount of data returned in the timeseries query will make tiles in dashboards load faster.
28 Mar 2025 08:12 AM
That makes sense! Thank you as well
28 Mar 2025 01:27 PM
We flipped our methodology on this recently.
We created a hidden variable ($app_servers) to create a list of hosts:
Note: that hidden variable needs to be multiselect and default to *
|fieldsAdd tags
|filter in(concat("client:",$Client),tags) and in(concat("environment_type:",$Environment),tags)
|fields id
Then our tiles became much simpler by providing a host list.
|filter in({$app_servers}, dt.entity.host)
|fieldsadd hostname=entityName(dt.entity.host)
