DQL
Create SLOs for Synthetic Browser Monitors Using DQL
robin_vogels
Newcomer
I would like to create a SLO for synthetic browser monitor duration < 2000ms. I successfully created a SLO for HTTP synthetic monitors, but I'm struggling to get the same working for synthetic browser monitors.
Can anybody help out?
4 REPLIES 4
p_devulapalli
DynaMight Leader
DynaMight Leader
@robin_vogels At what stage are you exactly facing issue when creating the SLO for HTTP synthetic monitors?
Phani Devulapalli
@p_devulapalli, I'm able to create the SLO with this DQL:
fetch dt.synthetic.events
| filter dt.synthetic.monitor.id == "HTTP_CHECK-XXX"
| makeTimeseries {total = count(), good = countIf(result.statistics.duration < 2000)}
| fieldsAdd sli = 100 * (good[] / total[])
However when I try to to the same for a synthetic browser test I found out that these events are not stored in dt.synthetic.events, so I tried to get it working with dt.synthetic.browser.duration, but I'm not able to create a SLO for it.
Do you have any idea how to achieve this?
@robin_vogels Here is a example which is similar to what you are trying to achieve . You can try using dt.synthetic.browser.duration instead here , you can may be ignore the tags part and use dt.entity.synthetic_test to filter it down to the particular test you are after and the expressions
https://docs.dynatrace.com/docs/shortlink/service-level-objective-examples#service-performance-for-s...
Hope this helps
Phani Devulapalli
Kenny_Gillette
Dynatrace Leader
Dynatrace Leader
Add ms:
| makeTimeseries {total = count(), good = countIf(result.statistics.duration < 2000ms)}
