DQL
Filtering Kafka metrics in Dynatrace for specific brokers and consumers
koti521
Newcomer
we have a single Dynatrace for multiple Kafka instances. I want to filter it out to my Kafka brokers and consumers.
I want to filter my Kafka brokers and producer information only, instead of displaying all other producer and brokers information in my dashbaord.
Hi @koti521 ,
Tagging is the best way here. Each of your Broker or Consumer is discovered as a new entity or pull them into your management zone using entity Selector rule
Once you pull these into your management zone then you can filter using that.
Maheedhar
Mizső
Hi @koti521,
Or on Classic Dashboard you can use dynamic filters:
I hope it also helps.
Best regards,
János
