DQL
Get all problems for a specific tag ("Application") on a service and a specific tag on a host ("Environment")
jmoormann
Newcomer
Been trying to work out a DQL to get all the problems from events where the service with the problem is filtered on a custom tag called "Application", and where the host the service runs on is filtered on a custom tag called "Environment".
Been working with support, but they suggested asking here for additional help. So far I have this query:
fetch events
| filter event.kind == "DAVIS_PROBLEM"
| lookup sourceField:runs_on[dt.entity.host], lookupField:id, fields:{host.name = entity.name}
| fieldsAdd entity.type, lifetime, tags
| filter matchesValue(entity_tags,"Application:ContractHub")
| filter event.status != "CLOSED"
| summarize Problems = count()
 However, I am getting a syntax error on the lookup section:
There aren't enough parameters for command `lookup`. 1 mandatory parameter is missing: lookupTable. lookupTable: Sub-query for records with fields to add or overwrite in the input.
I don't see a "lookupTable" argument in the docs (https://www.dynatrace.com/support/help/platform/grail/dynatrace-query-language/commands#lookup), so not sure what to change
Thanks!
ChadTurner
DynaMight Legend
DynaMight Legend
While this is an older posting, there is a new Problems Page that I recommend you take a look at as it might help you solve your issues.
-Chad
Fin_Ubels
Dynatrace Champion
Dynatrace Champion
While I'm not sure what the docs had at the time of the original post there are some great examples of how to use the lookup command now which can be found here: https://docs.dynatrace.com/docs/platform/grail/dynatrace-query-language/commands/correlation-and-joi...
As for specifically what is wrong with the above mentioned query, you need to specify a table to fetch from. So it would look something like:
| lookup [fetch dt.entity.host], sourceField:runs_on[dt.entity.host], lookupField:id, fields:{host.name = entity.name}
When doing a lookup, you are running a whole other DQL command and then using the source/lookup field to match records together. So within the [] you can do much more than just the fetch as well.
