08 Jul 2024 10:26 AM
Hi ,
I want to write one DQL which can compare jvm metric i.e. dt.runtime.jvm.threads.count data of two timeframe. Can somebody please how I can use lookup to join the two data set here.
I want to show metric name and average of thread count samples of 2 timeframe
Metric name June test 1 June Test 2
dt.runtime.jvm.threads.count 59 69
08 Jul 2024 12:54 PM
Any help will be appreciated
Heramb Sawant
08 Jul 2024 10:03 PM
I hope it helps:
timeseries tc=avg(dt.runtime.jvm.threads.count), from: "2024-07-01T00:00", to: "2024-07-02T00:00"
| lookup [
timeseries tc_ref=avg(dt.runtime.jvm.threads.count), shift:-1d
], sourceField:timeframe, lookupField:timeframe, fields:{tc_ref}
| fields metric="dt.runtime.jvm.threads.count", test=arrayAvg(tc), tc_ref=arrayAvg(tc_ref)Kris
10 Jul 2024 01:47 PM - edited 10 Jul 2024 01:47 PM
Thanks Kris for providing this DQL, this definitely giving comparison but I am specifically looking to compare two test release timeframes. I modified dql by adding test timeframe window like below but tc_ref is giving null .
timeseries tc=avg(dt.runtime.jvm.threads.count), from: "2024-06-04T00:00", to: "2024-06-05T00:00"
| lookup [
timeseries tc_ref=avg(dt.runtime.jvm.threads.count), from: "2024-07-04T00:00", to: "2024-07-05T00:00"
Please help . is there need to change lookup and source Field??
Heramb sawant
10 Jul 2024 07:43 PM
What shift: parameter does is some sort of "cheating" 😉. It shifts the timeframe specified in the basic query parameters and maps the resulting data points to timestamps from the original timeframe. Because I used lookup requires joining condition I used timeframe frame, because it was the same due to this effect. Logically in this case join condition is not needed, because both queries will return always 1 record.
You can observe this effect on chart when we remove aggregation to single value. I used append so we can have 2 different records, each with individual timeframe. This query:
| append [
]Produces this result:
black line represents data for June 30th, but it is mapped into July 1st
Result of such query:
| append [
timeseries tc_ref=avg(dt.runtime.jvm.threads.count), from: "2024-06-30T00:00", to: "2024-07-01T00:00"
]looks like this:
and in raw form:
As you can see timeframe field is different, so when used in lookup join condition it did not connect records.
There are many possible solutions. This way:
| append [
timeseries tc=avg(dt.runtime.jvm.threads.count), from: "2024-06-30T00:00", to: "2024-07-01T00:00"
| fields timeframe, tc = arrayAvg(tc)result will be presented with 2 rows and by looking at timeframe column, you can see what is actual and what is reference value:
but you can always combine this into single row:
| append [
| summarize {tc=takeAny(arrayAvg(tc)), tc_ref=takeAny(arrayAvg(tc_ref))}, by: {metric="dt.runtime.jvm.threads.count"}
12 Jul 2024 01:21 PM
Thanks you so much for the examples with detailed explanation.
Heramb Sawant
