DQL
Using Variable in DQL filter with matchesPhrase
pditmar2
Frequent Guest
I am trying to use a variable in a filter in DQL on my dashboard.
The $requestId variable is created as following :
fetch logs
| filter matchesValue(content, "* RequestId=*")
| parse content, "LD ' RequestId=' [a-zA-Z0-9]*:requestId",
    parsingPrerequisite: contains(content," RequestId=")
//| fields requestId2 = toUid(requestId)
| filterOut requestId == "null"
| summarize distinctrequestId = collectDistinct(requestId)
| expand distinctrequestId
| sort distinctrequestId
The results of the variable query are for example :
09b4597940e040caaa5fd3a2b5801451
27c9e98b933b42a4b7d27923c52c8235
299a6d18441a42b9a0b3a5c6dc22b1a9
On my dashboard I try to apply a filter on the $requestId as following :
fetch logs
| filter matchesValue(content, "*$requestId*") AND matchesValue(content, "* RequestId=*")
Unfortunately I run into the following error :
      "errorType": "PARSE_ERROR",
      "errorMessage": "`e9d2e0eb03eb48449fef78e6fe9d7130` isn't allowed here. Please check the autocomplete suggestions before the error for alternative options.",
      "arguments": [
        "`e9d2e0eb03eb48449fef78e6fe9d7130`"
      "queryString": "fetch logs\n| filter matchesValue(content, \"*\"e9d2e0eb03eb48449fef78e6fe9d7130\"*\") AND matchesValue(content, \"* RequestId=*\")",
      "errorMessageFormatSpecifierTypes": [
        "INPUT_QUERY_PART"
If I remove the $variable and just add one of the results it works fine. The problem seems to be that the \" that are added around the variable.
Is there any way to fix this?
Patrick
marco_irmer
Champion
It's a bit tricky because you're attempting to do a wildcard search here, whereas Dynatrace insists on enclosing the string variable value in quotations during query executions.
As a workaround, I recommend using the concat function to wrap the variable value in wildcards. The revised DQL will look like this:
fetch logs
| filter matchesValue(content, concat("*", $requestId, "*")) AND matchesValue(content, "* RequestId=*")
Thanks a lot, that works!
