Variable in AWS tag filter not working
aled
Visitor
I have a DQL query that is working as expected:
timeseries approximate_number_of_messages_visible=avg(cloud.aws.sqs.approximate_number_of_messages_visible), by: { dt.entity.custom_device } , filter: { in(dt.entity.custom_device, classicEntitySelector("type(custom_device),tag(\"[AWS]environment:prod\")")) }
| fieldsAdd entityName(dt.entity.custom_device)
| fieldsAdd approximate_number_of_messages_visible=arrayLast(approximate_number_of_messages_visible)
| sort approximate_number_of_messages_visible desc
| limit 20
However, I am trying to make the environment filter dynamic in my dashboard using variables, but as soon as I replace the prod string in the classicEntitySelector with a variable, I receive a parse error:
timeseries approximate_number_of_messages_visible=avg(cloud.aws.sqs.approximate_number_of_messages_visible), by: { dt.entity.custom_device } , filter: { in(dt.entity.custom_device, classicEntitySelector("type(custom_device),tag(\"[AWS]environment:$Environment\")")) }
| limit 20
Here's the error with $Environment value being "prod"
> Parse error.`prod` isn't allowed here. Please check the autocomplete suggestions before the error for alternative options.
By looking at the JSON error, I can see that the variable is "escaped":
"queryString": "timeseries approximate_number_of_messages_visible=avg(cloud.aws.sqs.approximate_number_of_messages_visible), by: { dt.entity.custom_device } , filter: { in(dt.entity.custom_device, classicEntitySelector(\"type(custom_device),tag(\\\"[AWS]nig_environment:\"prod\"\\\")\")) }\n| fieldsAdd entityName(dt.entity.custom_device)\n| fieldsAdd approximate_number_of_messages_visible=arrayLast(approximate_number_of_messages_visible)\n| sort approximate_number_of_messages_visible desc\n| limit 20",
Is there a way to "unescape" it?
mark_bley
Dynatrace Champion
Dynatrace Champion
Yes, you need to use concat for these values e.g.:
fetch dt.entity.cloud_application
| fields id, namespace.name = namespaceName, Name = entity.name, Type = arrayFirst(cloudApplicationDeploymentTypes)
| filter namespace.name == "openshift-etcd-operator" AND Type != "KUBERNETES_POD"
| filter in(id, classicEntitySelector(concat("type(CLOUD_APPLICATION),toRelationship.isClusterOfCa(type(KUBERNETES_CLUSTER),entityName.equals(",$Cluster,"))")))
Something lik this for your use case:
classicEntitySelector(concat("type(custom_device),tag(\"[AWS]environment:", $Environment, ")"))
