07 Jul 2025
12:40 PM
01 Dec 2025
01:57 PM
Michal_Gebacki
Hi
I am using a Table visual in a Dashboard where I can succesfully change the background colour for columns that are numerical by configuring thresholds
Is it possible to drive colour changes based on "text" values? see screenshot example - it would be for my "Status" columns in attached imaged
I cannot see a way of doing this? is it possible? any workarounds?
Apprecaite your time
Alan
08 Jul 2025 05:55 AM
Thanks Phani - not sure how I missed that 🙂 - works great thanks
One limitation however is that there is one global setting for either highlighting the "Value" or the "Background" for all columns in the table - its basically a global "either" "or" setting - it would be great is there was an option for each threshold column to be able to define either "Value" or "Background" highlighting - this would allow more flexibility
Appreciate the help
