Dashboarding
Creating a Dynatrace Collector Dashboard for Data Ingestion Monitoring
PeteBush
Observer
Hi I have a number of Kubernetes hosted Dynatrace Collectors running in our different environments and enabled self monitoring to keep an eye on their performance and usage. I have installed the dashboards from the hub (OpenTelemetry Dashboards monitoring & observability | Dynatrace Hub) but notice it's difficult to identify which collector is which as it only gives the service.instance.id to separate out the collectors.
Is there anything I can add in the dashboard to identify which Kubernetes cluster the collector is running in?
Pete
0 REPLIES 0
