Dashboarding
Dashboards with filtering data using variables
I have a dashboard with variable captured from bizevents data. It is a numeric value (type long). I want to filter bizevents for values choosen in the variable list. Single value works fine because it is enough to use "| filter positionDepot == toLong($positionDepot)". In the multiselect in my opinion I should use "| filter in(positionDepot, array($positionDepot)"
But it doesn't work. I mean there is no error but tile says "The are no records"
The workaround for it is:
Variable definition:
fetch bizevents
| filter event.provider == "XXXXX"
| fields positionDepot = toString(positionDepot)
| summarize positionDepot = collectDistinct(positionDepot)
Tile DQL query:
fetch bizevents
| filter in(toString(positionDepot), array($positionDepot))
| fields timestamp, positionDepot
In this setup everything works fine but in my opinion it can be done in a proper way.
Any ideas how to do it?
Best Regards
Patryk
AntonPineiro
I will provide and example to filter a table by hostname.
Variable:
fetch dt.entity.host
| fieldsKeep entity.name
 DQL query:
| filter in(entity.name, array($HOSTNAME))
 Important is variable only return values about one dimension. I am using "fieldsKeep" to have just values in one field.
I would use something as that, instead of summarize + collectDistinct.
Best regards
