19 Oct 2022
09:26 AM
23 May 2023
02:39 PM
Michal_Gebacki
We have two different types of metrics and we want to showcase "Graph" using data from them.
Objective: Count the number of jobs in a particular job status and show it's showing a historical time chart
Metric1: JobsInPlanCount
application_wa_JobsInPlanCount_job{jobstatus="ERROR"} 16
application_wa_JobsInPlanCount_job{jobstatus="SUCCESSFUL"} 15
application_wa_JobsInPlanCount_job{jobstatus="RUNNING"} 0
application_wa_JobsInPlanCount_job{jobstatus="SUPPRESS"} 0
application_wa_JobsInPlanCount_job{jobstatus="READY"} 4
application_wa_JobsInPlanCount_job{jobstatus="WAITING"} 10
application_wa_JobsInPlanCount_job{jobstatus="UNDECIDED"} 0
application_wa_JobsInPlanCount_job{jobstatus="HELD"} 0
application_wa_JobsInPlanCount_job{jobstatus="CANCELED"} 0
application_wa_JobsInPlanCount_job{jobstatus="BLOCKED"} 0
Dimension key: "jobstatus" (Only one)
Aggregation: Auto(avg) and Graph.
Result: Correct result was observed even though time duration was varied (2 hrs , 6hrs, 24hrs , 72 hrs , 7 days etc)
Code used is : wa.metric.application_wa_JobsInPlanCount_job:splitBy(jobstatus):sort(value(auto,descending))
Metric2 : JobsByWorkstation
application_wa_JobsByWorkstation_jobs{jobstatus="UNDECIDED",workstation="/MASTERAGENTS"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="HELD",workstation="/WA_SAGT_0"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="HELD",workstation="/WA_SAGT_1"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="SUPPRESS",workstation="/MASTERAGENTS"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="SUCCESSFUL",workstation="/HWA-GKE-SERVE_XA"} 7
application_wa_JobsByWorkstation_jobs{jobstatus="CANCELED",workstation="/WA_SAGT_0"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="CANCELED",workstation="/WA_SAGT_1"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="BLOCKED",workstation="/MASTERAGENTS"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="ERROR",workstation="/HWA-GKE-SERVE_XA"} 1
application_wa_JobsByWorkstation_jobs{jobstatus="WAITING",workstation="/HWA-GKE-SERVE_XA"} 4
application_wa_JobsByWorkstation_jobs{jobstatus="READY",workstation="/WA_SAGT_0"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="READY",workstation="/WA_SAGT_1"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="SUPPRESS",workstation="/HWA-GKE-SERVE_XA"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="UNDECIDED",workstation="/WA_SAGT_1"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="UNDECIDED",workstation="/WA_SAGT_0"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="READY",workstation="/MASTERAGENTS"} 4
application_wa_JobsByWorkstation_jobs{jobstatus="RUNNING",workstation="/MASTERAGENTS"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="WAITING",workstation="/MASTERAGENTS"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="SUCCESSFUL",workstation="/MASTERAGENTS"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="BLOCKED",workstation="/HWA-GKE-SERVE_XA"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="BLOCKED",workstation="/WA_SAGT_1"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="BLOCKED",workstation="/WA_SAGT_0"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="ERROR",workstation="/WA_SAGT_0"} 6
application_wa_JobsByWorkstation_jobs{jobstatus="CANCELED",workstation="/HWA-GKE-SERVE_XA"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="ERROR",workstation="/WA_SAGT_1"} 9
application_wa_JobsByWorkstation_jobs{jobstatus="SUCCESSFUL",workstation="/WA_SAGT_1"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="RUNNING",workstation="/HWA-GKE-SERVE_XA"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="HELD",workstation="/HWA-GKE-SERVE_XA"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="SUCCESSFUL",workstation="/WA_SAGT_0"} 8
application_wa_JobsByWorkstation_jobs{jobstatus="WAITING",workstation="/WA_SAGT_1"} 2
application_wa_JobsByWorkstation_jobs{jobstatus="UNDECIDED",workstation="/HWA-GKE-SERVE_XA"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="WAITING",workstation="/WA_SAGT_0"} 4
application_wa_JobsByWorkstation_jobs{jobstatus="RUNNING",workstation="/WA_SAGT_1"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="READY",workstation="/HWA-GKE-SERVE_XA"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="RUNNING",workstation="/WA_SAGT_0"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="HELD",workstation="/MASTERAGENTS"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="CANCELED",workstation="/MASTERAGENTS"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="SUPPRESS",workstation="/WA_SAGT_0"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="SUPPRESS",workstation="/WA_SAGT_1"} 0
application_wa_JobsByWorkstation_jobs{jobstatus="ERROR",workstation="/MASTERAGENTS"} 0
It has two dimenshion keys : "jobstatus" and "workstatus"
Dimension key: "jobstatus" and "workstation (Only two)
Aggregation:
(a) Auto(avg) not working because giving a decimal value for it (which is incorrect).
(b) Sum is giving extrapolated value
[ have a look to the attached screenshots ]
Kindly, tell me how to avoid these erroneous results.
Thank You
20 Oct 2022 03:51 PM
At the first glance, all depends on your fold transformation selection.
According your selection, the aggregation Auto(avg) and an Auto fold transformation on the result, the single average values are summed up (same as described here).
You can do the following things:
16 Dec 2022 03:08 PM
It is difficult to tell without an idea of the underlying data. It looks like the data is constant over time e.g. this line below:
is ingested multiple times with a constant value of 4. In which case the average would be 4 as expected, but the sum with this line
would lead to 6.
If aggregated over time, then it is expected to increase with coarser resolutions.
What would be the desired output when using the 2nd metric and aggregating over Workstation?
