09 Feb 2024
12:38 AM
09 Feb 2024
08:40 AM
Hi Team,
I have encountered a n issue with the Grail dashboard datetime variable; there appears to be a consistent 10+ hours difference with the datetime displayed in my laptop. the variable $dt_time_from and $dt_timeframe_to are not reflecting the correct local time as set on my system. this is resulting in misalignment between data represented in the dashboard and actual local time. Could you please help me with this?
09 Feb 2024 01:42 PM
Did you confirmed if you are running the same timezone in Dynatrace as your pc?
https://docs.dynatrace.com/docs/get-started/dynatrace-ui#user-menu-latest-dynatrace
11 Feb 2024 11:09 PM
Yes, it is set to use browser default and browser default is set to use local timezone>
14 Feb 2024 12:13 AM
Hi Team,
Can I please request for further assistance on this issue?
13 Aug 2024 01:29 PM
Hi @ash2
Have you managed to solve the problem? It would be great if you could share the solution with the Community users. 💡
13 Aug 2024 01:36 PM
I've noticed the same behavior
24 Sep 2024 02:32 AM
There is no straightforward way. I have written a custom function to convert this into a required timezone.
26 Sep 2024 10:53 AM
Hi @ash2
Peter.
