Dashboarding
Find transaction/volume per hour for any application
heramb_sawant
Organizer
Hi ,
I am  looking for a way to showcase volume per hour for any application and showcase it on dashboard based on selected timeframe in timeframe selector. .Please suggest best way to do it.
Heramb Sawant
3 REPLIES 3
dannemca
If by application you mean RUM (Web, mobile, custom), the best way to do it is using USQL, something like "SELECT count(userSessionId), useraction.application FROM usersession GROUP BY useraction.application" https://docs.dynatrace.com/docs/platform-modules/digital-experience/session-segmentation/custom-quer...
Or you can also do it using the bultin metrics, such as builtin:apps.web.activeUsersEst
https://docs.dynatrace.com/docs/observe-and-explore/metrics/built-in-metrics#web-applications
If you are looking for backend applications, then it is better to use a builtin metric, such as builtin:service.requestCount.server
https://docs.dynatrace.com/docs/observe-and-explore/metrics/built-in-metrics#ranges
How I can find this volume( transactions) per hour and display on dashboard?
is this possible using grail as well ??
Heramb Sawant
Unfortunately, application data is not yet in grail, https://docs.dynatrace.com/docs/observe-and-explore/metrics/built-in-metrics-on-grail
