I am trying to import data from an excel document hosted in the cloud to a Dynatrace dashboard to display this information. I see in the new gen 3 functionality there is a "code" tile option so ideally we would use that.
Go to option >> visualisations and select the RAW option.
I don't know how official this is, but you can easily extract the data the tile returns.
Radek
Hey Radek,
The problem is we cannot get the data in the first place. The dataset is to large to do this manually so we are looking for a scalable option for importing this data from our SharePoint.
Do you want to download data to Dynatrace from Sharepoint or from Dynatrace?
